phpList 3.4.5 Release Candidate ready for testing
A Release Candidate for upcoming phpList 3.4.5 is now available for testing.
This release includes fixes, usability & functional improvements
Changes to look for
  • Replace the SQL query to get more data on the CSV export of subscriber data – see the pull request
  • Add CSV export option for Campaign Click Statistics on the mclick page – see the pull request
  • Link the unique clicks column on the campaign click stats page to list of individual subscribers for easier discovery of the additional stats – see the pull request
  • use sql_affected_rows() when showing number of deleted bounces, both unidentified and processed – thanks to @duncanc, see the pull request
  • Fix error display on Trevelin β€œFatal Error: Unable to create campaign, did you forget to upgrade the database?” – thanks to @duncanc for providing the fix for this particular error and drawing attention to the error handling logic on Trevelin. More details on the original mantis issue
  • Change Regex to improve matching of email addresses within a bounce – thanks to @duncanc, see the pull request
  • Redesigned README page on phpList3 repo on GitHub for a more friendly display of all information related to phpList – https://github.com/phpList/phplist3/blob/master/README.md
Full list of changes here.
Download the Release Candidate here (see also β€˜Upgrading’).
Guidelines
Upgrading
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on August 11th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting β€œ3.4.5-RC1” as the Product Version.
Happy testing!
