Hi all,
Is it PHP 8.2 supported? If yes it doesn’t seem to work, at least in my setup.
It always throws an error at config 156 line where I define the array with users to run the cron from cli.
Example:
PHP Fatal error: Uncaught Error: Undefined constant “web70” in /var/www/clients/client1/web70/web/config/config.php:156
$commandline_users = array(“admin”);
As soon as I commend that line it works fine.
Any workaround on this?
