Simply add the following to your config/config.php file
# if you change the path to the phpList system, make the change here as well
$pageroot = ‘/newsletter’;
@Rlaila You might have entered the wrong value for “Website address (without http://)” on the Settings page. That needs to be where phplist is installed.
Also, there are a number of urls on the Settings page, such as “URL where subscribers can sign up”. Those might need to be changed as well.
Thanks for your tip. but nothing was running. Then I decided to delete everything and to let ist install again for the server automatic from hoststar.ch Now he create the right path, all Problems are gone
