We have been using PHPList for a couple of years now, but I have noticed that PHP List does not record the bounces for us. Is that a bug, or I have some configuration issues that I need to look for?
Hi!
It sounds like your bounce settings are not setup correctly. Here’s a link to the part of the manual that goes over how to configure that:
https://www.phplist.org/manual/ch040_bounce-management.xhtml
Please make sure that all is setup correctly, and if you still have issues, please let us know.
Regards,
Dan
I believe that’s the issue. Thanks you for the prompt reply. I will look into the settings and report back if I come across any problems.
Best Regards,
Fahad
