I tried phplist for the fisrt time,
It’s look good, but i’have got some 404 error.
So i whish check if my nginx.conf file looks good.
But i didn’t found a nginx configuration file for phplist.
for exemple, I have a 404 when i clic on
"Start a new message" in sens a campagn
Here my config.
upstream php-handler {
server 127.0.0.1:9000;
server {
listen 80;
listen [::]:80;
server_name mailing.domaine.com;
location / {
rewrite ^ https://domain$request_uri? permanent;
server {
listen 443 ssl;
listen [::]:443 ssl;
root /var/www/localhost/htdocs/phplist/;
index index.php index.html;
ssl on;
ssl_certificate /etc/ssl/private/auto.certificat.pem;
ssl_certificate_key /etc/ssl/private/auto.certificat.pem;
ssl_session_timeout 5m;
# Add headers to serve security related headers
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
add_header Strict-Transport-Security 'max-age=31536000; includeSubDomains;';
charset utf-8;
location ~* \.(txt|log|inc)$ {
allow 127.0.0.1;
deny all;
location ~* \.(js|css|png|jpg|jpeg|gif|ico)$ {
expires max;
log_not_found off;
#block phplist config directory
location /config {
deny all;
#per the phplist .htaccess these are the only public allowed php files
location ~* (index\.php|upload\.php|connector\.php|dl\.php|ut\.php|lt\.php|download\.php)$ {
fastcgi_split_path_info ^(.|\.php)(/.+)$;
include fastcgi_params; #standar fastcgi config file
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_intercept_errors on;
fastcgi_pass php-handler;
