New plugins for phpList3
I’m Christian from Germany. My profession contains knowledge in TYPO3, php, now phplist and many other stuff in web technology.
I created to plugins for phpList 3 as they where request at my workplace. I hope here is the right place to add them for review.
Kind regards
Christian
@chrbieber Great, they look good and useful.
The convention for naming plugins on GitHub is phplist-plugin-xxx so you might want to conform with that. The names of the actual php classes are fine.
On the Manage Plugins page there is a “Find plugins” button that goes to plugins:start [phpList Resources] , a docuwiki site, which is where most plugins are documented. You would need to login to that site though, and I don’t remember who controls that. There is a register link on the login page so you could try following that.
I have a couple of comments on the two plugins and will raise those as issues on GitHub.
Thanks @duncanc for the feedback. I renamed the repository according to the guideline.
So far I cannot add the plugins on that page.
I’ll take a look in your comments and see if I will follow your recommendations.
Kind regards
Christian
