Hi all,
I need to change the Innodb format to Barracuda as this is required by some applications. Will this cause problems for the correct functioning of phplist?
Thank you very much in advance.
Best regards,
John Bijnens
Hi all,
Best regards,
John Bijnens
Hi John, I am wondering the same thing. Sounds like you might be using moodle…
What have you learned about this? thanks.
