Shipments have started, but unfortunately slowly. My smtp gives me 12,000 sends per hour or 4 messages per second, while my campaign averaged 1,500 sends per hour.
The list I used for this campaign has around 33,000 subscribers, and it stopped after 12,971 sends.
Why was my campaign stopped and I can’t continue?
Regarding speed, below are the parameters defined in my config.php file:
I did everything exactly from the command line, but I think I figured out the problem.
I checked the phpList log and noticed numerous attempts to send messages to invalid email addresses. It must have stopped because of that, I cleared the list and am importing again.
@Lucas I have already explained that. You appear to be using “remote queue processing”, instead you need to use php command line as described in the link that I gave, e.g.
@Lucas yes that looks ok. You probably want to create a cron job to run the command periodically. Best to use the same user as the web server (often www-data or apache) not the root user for that.
@duncanc But why does it keep sending so slow?
My SMTP has a capacity of 12000 submissions per hour.
I want to work with an average of 10000 submissions per hour.
