I have a clean on prem installation of phplist version 3.6.14 and after installation i created a second administrator. Strange enough he has less rights and that seems correct, his entry is not showing the super admin field enabled but…
When i create a new admin the documentation does not match the fields i getpresented there is no option to create an admin with super admin rights as shown in the documentation Modifying Administrato... | phpList manual
The example add new administrator is from the documentation.
This is the screen shows when i want to add a new admin, that dhould be a Super Admin, the fields Is this a Super Admin and Is this account disabled are not availible in this version 3.6.14 at least not in my configuration.
@eelco Do you have any other phplist installations? If so, compare the row in the admin table to see any differences.
File lists/admin/admin.php line 251 onwards displays the selection for a superuser. Try dumping the value of $accesslevel . I guess it is not being set correctly.
You can probably make the second admin a super user by editing its row on the admin table, column superuser set to 1.
