Hey there,
I am trying to send the emails from the campaign and I get in the process queue Less than batch size were sent, so reloading imminently while using Amazon SES Plugin. I configured my email with Amazon SES with correct permissions and SMTP credentials but still could not send the email.
Hi @duncanc,
I checked the link you provided. From there I downloaded the plugin and installed on my phplist 3.4.5 latest release. Configured as per AWS SES and given in the documentation.
But still facing the same issue.
Hey @duncanc,
getting this error in log in events MailSender http code: 403, result: Sender SignatureDoesNotMatch The request signature we calculated does not match the signature you provided. with Less than batch size were sent, so reloading imminently. Is there something I am missing. I added given smtp credentials from ses to aws access key and secret and added endpoint prefixing with http://
The plugin uses the SES API not SMTP. You need specific credentials to use the API - access key id and secret access key.
If you only want to use SMTP then you don’t need the plugin. Just enter the SMTP server details and credentials in config.php as for any other SMTP server.
