Maintaining multiple PHPlist installations
I now have several installations of PHPlist on the same server. It is tiresome having to update each one.
Is there any way to run multiple installations from a single code base?
@mbrampton I would expect that having one set of code with each installation linking to that would work, but you will need to have some sound linux knowledge to do that.
But it is simpler to just use the Updater plugin which is now included in phplist. Once it is configured then updating phplist is only three button clicks plus a couple more to update the database. See plugin:updater [phpList Resources]
