Hi all
We would like to choose domain to send from, depending on different campains.
Can we somehow use different mailgun settings to different campaigns?
Hi all
@phplist The plugin does not currently support that.
Is it only the domain that would be different for a campaign, but the API key and the Mailgun URL would always be the same?
Okey!
Yes, the domain should be different!
And we can’t use the “account-api-key” unfortunately.
i don’t understand what you mean. Please can you explain what settings in Mailgun you want to be able to use.
Ah, sorry for a bad explanation!
I’ll try again
I am not a superuser in mailgun, but as I understand it you have a “Primary account API key” and then you can create “Domain Sending Keys”. In mailgun we have about 20 different “Domain sending keys”.
So what I would like was to be able to enter several different “mailgun settings” with different “Private API key”, “HTTP webhook signing key” and “Domain” in the phplist settings.
And then have the option to select different “Mailgun Configurations” for different campaigns.
