When creating a campaign I can send a test msg to myself and it works ok.
When I click on the ATTACH tab and add a pdf or jpg less than 500kb and then go to send a test to myself, I get a FAILED message and do not receive the test.
Found the log and it states that the file does not exist.
Since I browsed for the file and then did a save to system, I am assuming that something in the config file is not set properly.
My path to phpList is: root/public_html/club/phplist/public_html/lists
There is a tmp folder in each of the directories except directly under root all directories are empty
My config file has:
// set this to 1 to allow adding attachments to the mails
// caution, message may become very large. it is generally more
// acceptable to send a URL for download to users
// using attachments requires PHP 4.1.0 and up
define(‘ALLOW_ATTACHMENTS’, 1);
// when using attachments you can upload them to the server
// if you want to use attachments from the local filesystem (server) set this to 1
// filesystem attachments are attached at real send time of the message, not at
// the time of creating the message
define(‘FILESYSTEM_ATTACHMENTS’, 0);
// the attachment repository is the place where the files are stored (if you use
// ALLOW_ATTACHMENTS)
// this needs to be writable to your webserver user
// it also needs to be a full path, not a relative one
// for secutiry reasons it is best if this directory is not public (ie below
// your website document root)
$attachment_repository = ‘/tmp’;
//# if your SMTP server is called “smtp.mydomain.com” you enter this below like this:
//# define(“PHPMAILERHOST”,‘smtp.mydomain.com’);
define(‘PHPMAILERHOST’, ‘’);
// this is here, to make sure you edited the config file and mails are not sent “accidentally”
// on unmanaged systems
define(‘TEST’, 0);
You should create a directory purely to hold attachments then change this setting. /tmp is a system directory and likely to be emptied by the system. It may work for some installations but probably not for yours.
