Is it possible to Filter subscribers according to their behaviour
Is there any option in phplist to filter or sort subscribers on the basis of open time or click time.
Hi, I’m not aware of a way to do this via the web interface. That data is in the database, and might be available if you are able to write custom sql to extract or modify directly from it.
Thanks for the reply.
What does the segment plugin do?? does anybody know???
Have you looked at the documentation? https://resources.phplist.com/plugins/
What exactly are you trying to achieve?
I need to make subscriber lists according to the time they are opening the mails.
Example - if a person opens a mail in the morning I can put that person on a list which sends the emails in the morning.
@SystemAdmin phplist doesn’t provide a way of getting that information. As Dan suggested you would need to examine the database directly.
Thanks for replying.
