I am just wondering if Google’s invisible reCAPTCHA works with the reCAPTCHA plugin that is available. Does it only work with the regular checkbox reCAPTCHA?
Google has information here: https://developers.google.com/recaptcha/intro, but I am not really a developer, so I am hoping it would work. Otherwise, the checkbox would be okay. Just wondering. Thanks!
Please don’t feel pressure to develop something for the invisible approach. Using the checkbox method is fine. I just know that individuals will appreciate a simpler approach to completing forms. Keeping out these bots just seems like an unending struggle.
The plugin works with the v2 checkbox approach. Although when I developed the plugin, nearly three years ago, I think that was the only approach, I don’t remember any “invisible” recaptcha then.
