Hi Folks, I’ve just installed PHPLIST in my root folder which PHPBB is also in. For some reason the PHPLIST install failed and drew a blank page, even though I filled out the config.php, and updated with a change of name of the root folder by adding the following:
$pageroot = ‘/newfolder/’;
$adminpages = ‘/newfolder/admin’;
any ideas on how I can prevent problems with these 2 apps running in the same root folder? each has it’s own separate DB.
thanks!
