Hello people,
im trying to import CSV files, but it stops all the time. Any chance to attach a cron job to the import function also?
Hello people,
Hi, I’ve had this problem too, the cause was that there were illegal characters in the email address. The symptom was that the import would get to a certain record (say the 950th record), and then go no further). When I looked at that record in the csv file, it had some weird characters in the email address.
When I deleted that record, and re-imported, it fixed the problem.
I am trying to import emails in csv format but it is halting and I checked and no illegal characters I can spot. Please help
I prefer Tab Separated Values for import files.
This file removes email addys that have illegal chars.
out.txt is a much better import file.
I know it’s crudely written, but I threw it together in less than 10 minutes so cut me some slack.
Enjoy
<?php
// REMOVES BAD EMAIL ADDY'S... CREATES IMPORT FILE: OUT.TXT
if (file_exists("out.txt")) {unlink("out.txt");};
$cntinvalid=0;
$file = fopen("in.txt","r"); // Input file.
$file2 = fopen("out.txt","a"); // Output file.
fwrite($file2, "Email\tSend this user HTML emails\tRSS Frequency\tIs this account disabled?\n");
while(!feof($file)) {
$myline=strtolower(fgets($file));
$myline=rtrim($myline);
$myline=rtrim($myline,";");
if ((substr_count("$myline","@") <> 1) || ($myline[0] == '-')) {
echo "$myline --- @ ERROR - NOT VALID!<br />";
$cntinvalid++;
} else {
if((strpos("$myline",'`') == false) &&
(strpos("$myline",'~' ) == false) &&
(strpos("$myline",'!') == false) &&
(strpos("$myline",'#') == false) &&
(strpos("$myline",'$') == false) &&
(strpos("$myline",'%') == false) &&
(strpos("$myline",'^') == false) &&
(strpos("$myline",'&') == false) &&
(strpos("$myline",'*') == false) &&
(strpos("$myline",'(') == false) &&
(strpos("$myline",')') == false) &&
(strpos("$myline",'+') == false) &&
(strpos("$myline",'=') == false) &&
(strpos("$myline",'[') == false) &&
(strpos("$myline",'\{') == false) &&
(strpos("$myline",'\}') == false) &&
(strpos("$myline",']') == false) &&
(strpos("$myline",'|') == false) &&
(strpos("$myline",'\\') == false) &&
(strpos("$myline",':') == false) &&
(strpos("$myline",';') == false) &&
(strpos("$myline",'"') == false) &&
(strpos("$myline",'\'') == false) &&
(strpos("$myline",'<') == false) &&
(strpos("$myline",',') == false) &&
(strpos("$myline",'>') == false) &&
(strpos("$myline",'..') == false) &&
(strpos("$myline",'?') == false) &&
(strpos("$myline",'/') == false) &&
(strpos("$myline",'\t') == false) &&
(strpos("$myline",' ') == false)
fwrite($file2, "$myline\t1\t0\t0\n");
} else {
echo "$myline --- NOT VALID!<br />";
$cntinvalid++;
fclose($file);
fclose($file2);
$fileoutcnt = "out.txt";
$lineoutcnt = (count(file($fileoutcnt))-1);
echo "$cntinvalid addresses were invalid<br />$lineoutcnt are ready for import";
Can you see at which line the import hangs?
How can I find out? do you have a method?
Thank you so much but I have attributes need to be added to each email as well. what format do I need to save in.txt file (MS-DOS) Text or SCV Coma-delimited)?
plain text (MS-DOS or Unix)
One email addy per line.
My script creates just 3 attributes and presets them.
Send this user HTML emails = 1
RSS Frequency = 0
Is this account disabled? = 0
It says:
Importing 35255 subscribers to 4 lists, please wait
Please wait
1970 / 35255
Thanks but it still halts on Importing 35255 subscribers to 4 lists, please wait
Please wait
1970 / 35255
check line 1969, 70 and 71 - any errors in the address? Bad characters reek havoc
Nop
(image removed by admin)
I would try and import just the first 1960.
Then try and import the next 50 and see if there’s a problem.
If there’s no problem, I would assume that the import script is timing out.
How can I increase that?
Server Management:
Settings within PHP Configuration Editor
It should not require a recompile.
