@Liliplanet To clarify, you think that this is a problem only for apple ipad, and images are displayed as expected with other email clients such as gmail, outlook, yahoo?
You should compare the email html source of a “good” email with that of a “bad” email to see what the significant differences are.
Correct Duncan, I’ve tested on gmail, etc, it works, but apple (80% of my film clients) are on a mac. Its a new thing (latest mac upgrade) that does not download images re security.
It seems specifically due to any tracking that is an issue. What a nightmare for marketers.
Server tech even switched off security ie boxtrapper, no avail.
As I say, why would it work with test mail (images show), any other repeat, schedule, auto response, no images
As mentioned, images appear on mac mail when sent as a test …
but when auto respond, scheduled or repeat, I got a feeling there is still a tracking pixel in the mail that mac regards a privacy issue, so no images.
Tracking is still there even with no [USERTRACK] in html or template, and all settings switched off.
@Liliplanet Your statistics are showing no views so user tracking is disabled.
You said that a test email does display images. If that is still the case then as I suggested previously you should compare the html source of the “good” and “bad” emails to see what is different.
I don’t know whether it is significant but the URLs of the images have a token appended. What is that for? It might be being treated as a tracking device
