I want to sent all mails out at once, so I tried to turn off batch processing:
define('MAILQUEUE_BATCH_SIZE', 0);
But it showed no effect, only about 20 mails per minute are sent. What am I missing?
Although I got there in a different way, I have a similar experience.
Even with batch-size set at 0 to turn off batch processing, only a small number of messages are sent. I found that when I applied a mail queue throttle of 45 seconds, 7 messages were sent and then the sending stopped. Reducing the throttle to 40 seconds increased the messages to 8 before stopping.
What are your other settings?
define('MAILQUEUE_BATCH_PERIOD', 3600);
# (or you can play with the autothrottle below)
define('MAILQUEUE_THROTTLE', 0);
It may be the case that your host is limiting how many mails you can send in a specific period.
I just set the MAILQUEUE_BATCH_SIZE to 0. I assumed that turning off batch processing makes the other options redundant.
I’m sending through an external Microsoft server, so there is no limit.
I’m not sure about 0711master, but:
my hosting service imposes limits of 19 messages / minute, 100 messages / hour, and 10,000 /day
My settings are: batch size – 0 and batch period – 3600. When I used mail queue throttle – 45, phpList sent 7 messages and stopped; when I used throttle – 40, it sent 8 messages and stopped.
Earlier on, I had batch size of 5, periods of 500 and 225 – each of which resulted in just 1 message being sent and then stopping.
I also set define('MAILQUEUE_THROTTLE', 0); now, but no effect. Still only 25 emails per minute.
just to make sure, you are making these changes in the config.php file, not the config-extended.php file
Haha, yes…
