zaopao
August 23, 2016, 2:32am
#1
my php-5.4.35 phpList - v3.2.5
config.php
if set like this,it could be send email success;
define(‘PHPMAILERHOST’, ‘smtp.domain.com ’);
$phpmailer_smtpuser = ‘domain01@domain.com’;
$phpmailer_smtppassword = ‘password’;
$message_envelope = ‘domain01@domain.com’;
$bounce_protocol = ‘pop’;
$bounce_mailbox_host = ‘pop.domain.com ’;
$bounce_mailbox_user = ‘domain01@domain.com’;
$bounce_mailbox_password = ‘password’;
$bounce_mailbox_port = “995/pop3/ssl/novalidate-cert”;
$bounce_mailbox_folder = ‘INBOX’;
$bounce_mailbox = ‘/var/spool/mail/listbounces’;
$bounce_mailbox_purge = 1;
but set like this,it send email failed
$message_envelope = ‘domain02@domain.com’;
$bounce_mailbox_user = ‘domain02@domain.com’;
How can I set “ $message_envelope”?
Tanks for help.
Lucas
@zaopao The email address that you use must be valid for the domain, and must exist. You cannot just make up an email address and use that.
zaopao
August 23, 2016, 6:55am
#3
I’m sure the email address that I use is valid for the domain
@zaopao Try enabling smtp debug in your config file (if it is not there then look in config_extended.php for an explanation and copy the line).
Send a test message and there will be some output at the top of the page. That might explain what the problem is.
zaopao
August 23, 2016, 7:12am
#5
config file
$phpmailer_smtppassword = ‘*******’;
$bounce_mailbox_password = ‘******’;
//cartella della mail in cui leggere le mail bounced
LOG OF EVENTS
Error sending email to test@domain.com The following From address failed:domain02@domain.com : MAIL FROM command failed,Mail from must equal authorized user ,553,SMTP server error: MAIL FROM command failed Detail: Mail from must equal authorized user SMTP code: 553SMTP server error: MAIL FROM command failed Detail: Mail from must equal authorized user SMTP code: 553
@zaopao That is saying the email address bounce@exuewen.com is not authorised to send email. You will need to find out from the hosting company how to resolve that.
zaopao
August 23, 2016, 8:14am
#7
in this case I think I use smtpuser domain01@domain.com send email.
why it say domain02@domain.com is not authorised to send email.?
I just want use domain02@domain.com for receive。
zaopao
August 24, 2016, 2:50am
#8
My problem is phplist take the message_envelope as “from email”
but I just want use message_envelope for “”reply-to email“”
How can I do?
Lucas
@zaopao I don’t think that phplist supports using reply-to.
zaopao
August 24, 2016, 5:43am
#10
Yes,I understand
I mean how set config.php “ $message_envelope”?
the “ $message_envelope” email must be the same as smtpuser?
when I use “ $message_envelope” email not the same as smtpuser,it send failed.
but the “ $message_envelope” email the same as smtpuser,it send success.
I don’t know if I describe the problem clearly.
duncanc
August 24, 2016, 5:59am
#11
@zaopao Sorry but there is nothing more that I can add to this. You need to raise the problem with your hosting company.
