I want to handle my emails throw many domains/ip’s
for example if I have 5 ip’s and 5 attached domains like this :
example1.com x.x.x.x
example2.com y.y.y.y
example3.com z.z.z.z
example4.com x.x.x.x
example5.com u.u.u.u
and I want to select every once a set of those domains/ips maybe 2 or 3 o all of them
and rotate between them the flow ,it could be done with phplist without installing many instances of phplist?
also using a specific sender email for every sender domain/Ip
I think phplist is very strong it should exist a way to do so
can you help on that plz
thank you so much
