Hi there,
I have a site of 2000 contacts but my host only accepts 50 emails per hour.
How can I create a single campaign that sends 50 emails, waits an hour, and then 50 emails again.
Hi there,
use the throttling settings in the config.php.
one way to do it is to set a delay between emails…
if you batch period is 3600 seconds (an hour), and you want to send 40 emails per hour, the configure a delay for 3600secs/ 40 emails = 90 seconds. when sending this way, it’s best to setup a cron job for every 15 minutes or so.
