Is there a way to hide the auto-updater message and the auto-update menu item. I’ve added my own language set and don’t want the system auto-updating it to oblivion.
Thanks … Doug Davis
Thanks … Doug Davis
If you are using v3.3.8 or later and you want to disable the automatic updater and its notifications, add the following in your config.php:
file:
define(‘ALLOW_UPDATER’, false);
For some reason, that’s not working on my system… the updater keep showing the use the updater notification 3.39
I have added to my config and it works. BE SURE you have the semicolon at the end of the line.
I put it into the security related section immediately below the $Check for Host line.
I will paste a sample here …
# to increase security the session of a user is checked for the IP address this needs to be the same for every request. This may not work with
# network situations where you connect via multiple proxies, so you can switch off the checking by setting this to 0
define("CHECK_SESSIONIP",0);
# Check for host of email entered for subscription Do not use it if your server is not 24hr online
# make the 0 a 1, if you want to use it
$check_for_host = 1;
# AutoUpdater switch as described by Support
define ('ALLOW_UPDATER',false);
Debugging and informational
… (NOTE: the Bolded lines have a # before them) Hope that helps!
Doug Davis
Thanks @Dougster,
It turns out that I copied the line from @xheni which didn’t work.
Your code worked.
The apostrophes were not the proper character for php to interpret…
//this code works--
//this code does not work--- note improper apostrophes...
@danwaterloo It’s a problem with the Discourse software. It changes single quotes to so-called “smart quotes” (66 and 99 type) when you copy and paste. I think that doesn’t happen when you use the code button </> though.
e.g.
define('ALLOW_UPDATER', false);
@samtuke Sam, can you see whether this is a configuration option that can be changed? I remember this has happened before.
