I received the email below discussing the new options, but I don’t see any guide for how to implement them (the pull requests were not helpful). Is there a guide for how to use the subscription forms “across multiple websites.” Also, if I do this, I don’t understand how to use the ACCESS_CONTROL_ALLOW_ORIGINS.
Blockquote
New features
The AJAX-based subscription forms are now able to function across multiple websites. A new config constant called ACCESS_CONTROL_ALLOW_ORIGINS has been added which is an array where you can put in your different origins you want to allow. Also, a new header “Vary: Origin” has been added to optimize cache control in the case where the array option is used.- thanks to Nepomuk Leutschacher for the implementation. Have a look at the Pull Request. Additionally, now with the AJAX request, you can specify a particular list instead of all lists being used. Thanks to Duncan Cameron for the implementation. Have a look at the Pull Request.
@keeenone The change is only to do with providing a way to set different values for ACCESS_CONTROL_ALLOW_ORIGIN, instead of as previously only one host or ‘*’.
Take a look at the example in config_extended.php. You need to set either ACCESS_CONTROL_ALLOW_ORIGIN or ACCESS_CONTROL_ALLOW_ORIGINS but not both
Do you have a link where I can download the latest config_extended.php file? The auto-updater is not updating it. I found no references to anything with access control in my version.
This is very helpful but I find this note towards the bottom very confusing:
NOTE 5: If test=0 in your phpList config.php file, then all subscribers remain unconfirmed as no confirm mail is sent.
If I set test=1 in my installation it says that NO emails will be sent. Why would I need to set it to 1 to use the AJAX subscribe box on my website? Isn’t this what it is saying?
Indeed, the subscription form worked, however, it does show that the user is unconfirmed, and I can confirm that the system did not send out a confirmation email. How can I use this AJAX subscribe box AND have a confirmation email sent out?
Also, in NOTE 5 mentioned above, I assume we are talking about this area of the config file, and setting this to 1 would mean that I am running a test installation, and not a live installation, right?
// if test is true (not 0) it will not actually send ANY messages,
// but display what it would have sent
define(‘TEST’, 0);
So I have gotten the AJAX subscribe box script working on my site, however, it does not work for Safari browsers–which is now a huge number of Apple device users. Is there a version of this that works with Safari?
Sorry about all of the posts. Actually there does seem to be an issue with Safari on iPhones when using this form. I can get this working on the desktop with no issues, but have only got it to work sporadically on Safari. Any ideas?
