Hi, just installed phpList into my godaddy host account using installatron. Perfect. Very easy to use and setup - I really like. But one question. How many emails can I send out at a time in this environment? In other words, how large can my list be for any given campaign? My office manager was using Outlook and a mail-merge until I saw what he was doing and yelled “Stop!” Then I showed him this tool, and his eyes went gaga. But he was telling me that when using a Godaddy email account, he would get bounce notices for any merge larger than 500. Is that also true using phpList? Well, look forward to your answer, and to using this on our next campaign. I am a Mailchimp user myself, and I much prefer this tool over the chimp (cheaper, I think).
It is the rate of sending (number of emails per hour) that is important, not the absolute size of the list. Your office manager thinks that there is a limit of 500 - I guess 500/hour but you need to check that with Godaddy as it will depend on the type of hosting account that you have with them.
You need to add or modify these settings in your config.php file to reflect the limit on the rate of sending:
define("MAILQUEUE_BATCH_PERIOD",3600);
# (or you can play with the autothrottle below)
define('MAILQUEUE_THROTTLE',0);
