Hi
I’ve got two problems:
1 - In the model of the campaign added [FORWARDURL] and put config.php, define (“FORWARD_EMAIL_COUNT”, 1);
define (“FORWARD_PERSONAL_NOTE_SIZE”, 0);
define (“FORWARD_ALTERNATIVE_CONTENT”, 0);
On the sending test by clicking the linkrecebo the message “Not Found”
2 - In the model, in the footer, this item Send test. I put an email and it reports that failed to be sent, but does not show the error. How to know what is wrong?
It sounds like you might want to check the following values in your ‘Configuration’ ‘settings’:
The 'Website address (without the http) This is used to generate the links. Once you change this, go further down on the settings to check the other web addresses, and make sure they are correct.
If you can’t send, you should look in the system log… “System”, “Log of events”. It will usually provide some information that will be useful in troubleshooting. Off hand, it sounds like your send settings in the config.php file should be verified.
You can only send to an address that is in the contact database.
Just to clarify, you have tested this in an email which has been sent using the usual sending method, not just a test. It does not work in test emails.
I have the same problem as I get the failed message for Test Send at the bottom of campiagn page, and the error produced by Log of Events; Error sending email to amir@xyz.com Could not instantiate mail function.
