Forward to a friend failed
‘tried forwarding message … but failed’
a message i received, from a list that i administer, which i cannot forward
i see the error after submitting the form, and receive email notification of the failure
@wolfey Look on the Event Log page to see whether any error was reported.
I think that there might be a problem with the “forward to a friend” feature because the From address will be the subscriber doing the forwarding. The From address usually needs to be on the same domain as phplist, so trying to use an email address on any other domain may be rejected.
@wolfey might be helpful to point out that the forward option won’t work if the campaign is a draft campaign.
Semi
