I’m moving from mailchimp to phpList --> it’s set up on a linux shared hosting, but I’m considering to use an external smtp as mailgun or sendgrid. Which do you suggest?
I got like 5k email contacts and I’ll send a newsletter once a month and I’ll use a brand new domain, never used before.
Should I make a cron job or a mail queue? how? I’d like to avoid spamming behaviour and problems.
duncanc
September 28, 2017, 1:50pm
#2
Unless the hosting company imposes a very limited sending rate you can send 5,000 emails in a few hours through the local mail server, no need for an external provider like Mailgun.
It sounds like you need to find out what phplist actually does. Try the help documentation - click the “back to phplist.org ” link at the top of each forum page.
Thanks for your reply, @duncanc !
Actually at this moment I don’t know exactly the sending limit - that’s why I’m looking for an external provider.
I read all the manual. I don’t have a ssh access, so I’m using the phplist.com option.
I was wondering how can I set up limits to send emails. Like send 80 emails per hour and when it’s done wait some time…
duncanc
September 29, 2017, 6:01am
#4
@piotramp Look at batch size, batch period, throttle, etc in the config_extended file and copy those settings to the config.php file.
Hey @duncanc !
I’m trying using cron job. First of all I used easycron.com and I can see the output is a json. I found this guide about cpanel: https://forums.phplist.com/viewtopic.php?t=11712 .
And cron daemon in every email sent me the html source with Warning: commandline only works well with the cli version of PHP .
The command is:
/usr/bin/php /home/USER/phplist/admin/index.php -p processqueue
The reply from cPanel cronjob should it be like easycron? Like this?
{"campaign":0,"num_users_for_message":0,"batch_count":0,"batch_total":80,"sendemail returned false total":0,"send blocked by domain throttle":0,"add attachment error":0,"sendemail returned false":0,"sentastest":0,"invalid":0,"failed_sent":0,"sent":0,"num_per_batch":80,"status":"embargo","delaysend":null}
duncanc
October 2, 2017, 10:24am
#6
@duncanc just tried:
/usr/bin/php /home/USER/PHPLIST/admin/index.php -pprocessqueue -c/home/USER/PHPLIST/config/config.php >~/processqueue.log 2>&1
and processqueue.log :
X-Powered-By: PHP/7.1.6
Set-Cookie: PHPSESSID=1bc72bebb18711ae2f2f7f36fe2f73e1; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
X-UA-Compatible: IE=Edge
X-Robots-Tag: noindex
Content-type: text/html; charset=UTF-8
Warning: commandline only works well with the cli version of PHP<!DOCTYPE html>
<html lang="it" dir="ltr" prefix="og: http://ogp.me/ns#">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1" />
<meta name="License" content="GNU Affero General Public License, http://www.gnu.org/licenses/agpl.html" />
<meta name="Author" content="Michiel Dethmers - http://www.phplist.com" />
<meta name="Copyright" content="Michiel Dethmers, phpList Ltd - http://phplist.com" />
<meta name="Powered-By" content="phplist version 3.3.1" />
<meta property="og:title" content="phpList" />
<meta property="og:url" content="http://phplist.com" />
<link rel="shortcut icon" href="./images/phplist.ico" />
<link rel="icon" href="./images/phplist.ico" type="image/x-icon" />
<link rel="apple-touch-icon" href="./images/phplist-touch-icon.png" />
<link rel="apple-touch-icon-precomposed" href="./images/phplist-touch-icon.png" />
<!-- initial styles and JS from basic application -->
<!-- the CSS is already mostly minified -->
<link rel="stylesheet" href="css/app.css" />
<link rel="stylesheet" href="ui/phplist-ui-bootlist/css/style.css?v=1506496946" />
<title>phpList :: phpList :: Pagina di Amministrazione</title></head>
<body class="invisible login">
<div id="dialog"></div><div id="hiddendiv"></div>
duncanc
October 2, 2017, 11:35am
#8
@piotramp Did you try using php-cli
as the command?
@duncanc this is the command:
do you mean to replace /usr/bin/php
with just php-cli
duncanc
October 2, 2017, 12:43pm
#10
@piotramp Yes, just try that.
@duncanc wow!
I got this! is it right?
phpList version 3.3.1 (c) 2000-2017 phpList Ltd, http://www.phplist.com
phpList - Recently sent : 0
phpList - Iniziata [0,0197900000] (109)
phpList - Sending in batches of 80 emails [0,0004560000] (112)
phpList - Script - passo: 6 [0,0008400000] (116)
phpList - Finito, Niente da fare [0,0002260000] (117)
phpList - Finito, Tutto OK [0,0009680000] (123)
wow 5k email contacts - greate number
