brand new to PHPList, and am on a big learning curve. been working through setting it up and have got to the point where I can try and send my first campaign to a test list. there are three confirmed emails in the list. I built a template and applied it. placed some straight "lorum ipsun text and an image into the first message and followed the bouncing ball to the process que.
When I bagan t he process, I seemed to just be getting a continuous loop of Failed to send email error> I have no idea where error logs are or anything, but have full access to my server.
So, now Im at a loss here. I’ve obviously missed something. looking for some help to get this process working.
The installation is on s shared server (godaddy). PHPlist version is 3.6.10
@jeddell You are not being very clear. The default is not to use SMTP, so unless you have configured that in config.php phplist will be sending using the php mail() function.
This is the same for all three emails. So it appears as though the SMTP ‘setting’ (where-ever that is) is defaulted to enabled.
Again if im no clear, Im not familiar with the terminology that this community uses regarding PHPlist yet. Ive been playing with if for about two days total. I have had success in setting up the SMTP, but I would prefer NOT to use it .
Reading the github link, it mentions something about PHPmailer. Im guessing this may be important? Any info on whether this installs with PHPLists or is something that needs to be installed on top of it?
