I just installed phplist 3.3.1. It’s a complete new and default installation. I only inserted the MySQL-Data in config.php.
But unfortunately FCKeditor doesn’t work. When i created a new message, the windows, in which the editor normally appears is blank. Does anybody knows why?
Alternatively I can use the CKEditor, but there is the next problem. In my newsletter, I often user pictures, that are aligned right. In FCKeditor it looks like this:
<p><img src="https://discuss.phplist.org/uploads/phplist_site_logos/phplist_logo_discuss_opt.png" alt="" width="152" hspace="5" height="41" align="right" />Lorem ipsum dolor sit amet.</p>
Same created with CDEditor will be this:
<p><img alt="" src="https://discuss.phplist.org/uploads/phplist_site_logos/phplist_logo_discuss_opt.png" style="margin-left: 5px; margin-right: 5px; float: right; width: 152px; height: 41px;" />Lorem ipsum dolor sit amet</p>
In both editors it doesn’t look different, but the first HTML will be displayed correctly in Outlook 2010, the second not (the image does not appear on the right).
One last question, I couldn’t anwer myself: I want to use the TinyMCE-Plugin called “image tools” (for insert hspace to the image). Where can I insert that code for that (look here: https://www.tinymce.com/docs/plugins/imagetools/)?
Hmm, I just downloaded it with all possible plugins, installed it, edited the location in PHPList-config and TinyMCE looks the same. So where can I activate that plugin called “image tools”?
