In old versions of 2.10, I want to replace the FCK editor with the latest version of CK editor. I want a summarized list of steps to do that in order not to miss something, as I don’t think it’s just replacement of the folder with the new version.
Thank you.
@mailer The old 2.10.* version of phplist do not support alternative editors. You will need to upgrade to phplist 3 for that.
It’s just a plugin, I suppose it can be done with some modifications in code. Why do you say it’s not possible?
