I’m using the latest version of PHP list, with firefox (though I’ve tried with multiple browsers). I created a campaign as usual and noticed an issue when my test emails failed. I went ahead to try to process the queue. Each subscriber met with “Error.” I tried creating a new campaign, logging out, a different browser to no avail. I’m not sure what to do. I’m not a very tech savvy person!
Hi Katie,
To get at the config.php file, you’ll need to log onto the server, and look in the directory …/lists/config you’ll find it there. The … directory is the path where you installed the software.
If you need help, several of the people here offer paid help (including me). Here’s a link to the list:
Hi, yes as Dan suggests paid support is a good option for you. Or using phpList.com, where the install is fully managed for you. Running phpList is an advanced task really
How many mails are you sending? It might even be free or like $1 on phpList.com
