Hola buenas noches, active common plugin y se cerro admin, luego no pude ingresar mas y me indica error 500. ahora esto volviendo a cargar todo de nuevo. Alguna sugerencia?
@materialesanfra You can avoid having to reload the phplist code by renaming the plugin file so that phplist does not recognise it
lists/admin/plugins/CommonPlugin.php
to lists/admin/plugins/CommonPlugin.php.xxx
Look in the php or web server error logs for any error reported.
