Hi phpList,
I have been using phpList since 2015; due to hosting renew issues i have lost my data. For the last few months I have been trying to configure new system, and I have successfully installed phpList; But the problem is Email does not sent to subscribers )): Please suggest me.
Sumon Rahman
Hi Sumon,
Are you using the latest phplist update version? You should be dumping all your subscribers data to your desktop for re-uploading later and do some sweep and a clean install.
Max thanks for your support buddy. I did tried but failed. Is it possible to get install offer from you? or YouTube where I can see install process?
I am not sure if it’s okay to share link here but you may go and see this http://phplistmod.com
