I’m using PHPList 3.3.1 with PHP Version 5.6, the trash bin is not showing on the action menu on the list of campaigns (drafts – /admin/?page=messages&tab=draft) on my production server. However, on my local server (XAMPP) PHP Version 7.0.21, it shows up and works!
Is the PHP versions difference causing the issue? I made some config.php configuration changes on the production server, but even after resetting them to their original settings had no effect.
I will appreciate any insight into resolving the issue I’m having. Thanks.
