Domain Throttling Not Working
phpList v3.6.15
// Domain Throttling
define(‘USE_DOMAIN_THROTTLE’,1);
define(‘DOMAIN_BATCH_SIZE’, 100);
define(‘DOMAIN_BATCH_PERIOD’, 1000);
150 subscribers all the same domain
15104 msgs/hr
I am trying to set limit per domain at 100 and 10 seconds between emails to those domains. Domains under 100 can run at full speed.
Are my settings correct to achieve my desired outcome?
Are there other settings that also need to be adjusted?
Thank you.
