DKIM signing works in postfix. I don’t know how to set it up to work with dovecot’s authentication system.
let me post the postconf -nf and postconf -Mf
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
append_dot_mydomain = no
biff = no
compatibility_level = 3.6
inet_interfaces = all
inet_protocols = ipv4
mailbox_size_limit = 100000000000
message_size_limit = 100000000
milter_default_action = accept
milter_protocol = 2
mydestination = localhost.$myhostname, localhost, $mydomainname
mydomain = WEBSITE
mydomainname = /etc/postfix/virtual_domains
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128 localhost
myorigin = /etc/mailname
non_smtpd_milters = inet:localhost:8891
readme_directory = no
recipient_bcc_maps = regexp:/etc/postfix/archive_domain
recipient_delimiter =
relayhost =
sender_bcc_maps = regexp:/etc/postfix/archive_domain
smtp_sasl_security_options = noplaintext,noanonymous
smtp_sasl_tls_security_options = noanonymous
smtp_tls_CApath = /etc/ssl/certs
smtp_tls_security_level = may
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_banner = $myhostname ESMTP $mail_name
smtpd_delay_reject = yes
smtpd_recipient_restrictions =
permit_sasl_authenticated,permit_mynetworks,reject_unauth_destination,reject_invalid_hostname,reject_non_fqdn_hostname,reject_non_fqdn_sender,reject_non_fqdn_recipient,reject_unknown_sender_domain,reject_rbl_client
sbl.spamhaus.org,reject_rbl_client cbl.abuseat.org,check_sender_access
hash:/etc/postfix/sender_access,permit
smtpd_relay_restrictions = permit_mynetworks, permit_sasl_authenticated,
smtpd_sasl_auth_enable = yes
smtpd_sasl_path = private/auth
smtpd_sasl_security_options = noanonymous, noplaintext
smtpd_sasl_tls_security_options = noanonymous
smtpd_sasl_type = dovecot
smtpd_tls_auth_only = yes
smtpd_tls_chain_files =
/etc/letsencrypt/live/WEBSITE-0003/privkey.pem,
/etc/letsencrypt/live/WEBSITE-0003/fullchain.pem
smtpd_tls_ciphers = medium
smtpd_tls_security_level = may
smtpd_use_tls = yes
tls_server_sni_maps = hash:/etc/postfix/vmail_ssl.map
virtual_alias_domains = /etc/postfix/virtual_domains
virtual_alias_maps = hash:/etc/postfix/virtual
smtp inet n - y - - smtpd
submission inet n - y - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
-o smtpd_tls_wrappermode=no
-o smtpd_sasl_auth_enable=yes
-o smtpd_relay_restrictions=permit_sasl_authenticated,reject
-o smtpd_recipient_restrictions=permit_mynetworks,permit_sasl_authenticated,reject
-o smtpd_sasl_type=dovecot
-o smtpd_sasl_path=private/auth
-o smtpd_enforce_tls=yes
smtps inet n - y - - smtpd
-o syslog_name=postfix/smtps
-o smtpd_tls_wrappermode=yes
pickup unix n - y 60 1 pickup
cleanup unix n - y - 0 cleanup
qmgr unix n - n 300 1 qmgr
tlsmgr unix - - y 1000? 1 tlsmgr
rewrite unix - - y - - trivial-rewrite
bounce unix - - y - 0 bounce
defer unix - - y - 0 bounce
trace unix - - y - 0 bounce
verify unix - - y - 1 verify
flush unix n - y 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - y - - smtp
relay unix - - y - - smtp
-o syslog_name=postfix/$service_name
showq unix n - y - - showq
error unix - - y - - error
retry unix - - y - - error
discard unix - - y - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - y - - lmtp
anvil unix - - y - 1 anvil
scache unix - - y - 1 scache
postlog unix-dgram n - n - 1 postlogd
maildrop unix - n n - - pipe flags=DRXhu
user=vmail argv=/usr/bin/maildrop -d ${recipient}
uucp unix - n n - - pipe flags=Fqhu
user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail unix - n n - - pipe flags=F user=ftn
argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe flags=Fq.
user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe flags=R
user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop}
${user} ${extension}
mailman unix - n n - - pipe flags=FRX
user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py ${nexthop}
${user}
i cannot connect to the ports 465 or 587 for sending mail though the post fix system
i dont know how to get phplist to work well with dovecot. I need some pointers and help
