Yes yes… i did search. I get it, it is not possible.
But i messed up and did all the testing without checking the TEST checkbox, so i have 8 testing campaigns i would like to remove. Now i have the setup configured with many of the options, templates, logos, plugins and subscribers list.
I do not see any options to export the current configuration.
I can drop the database and start from scratch of course… but is there any other way, like removing certain tables in the database or any other work around?
Thank you
@axmail The Campaigns plugin will let you delete “sent” campaigns. On the Manage Campaigns page follow the “find plugins” link.
