I use this script after performing a lot of clean-up functions on my DB. If you haven’t optimized yours in a while, you should increase the sleep time a little bit.
Edit lines 4-7 with your info.
Upload the file to your server.
Use a browser to visit the URL of the script and it will execute.
It takes a while to run.
<?php
// OPTIMIZES ALL TABLES IN YOUR DATABASE
$servername = "mydomain.com"; //ENTER YOUR DOMAIN NAME
$username = "mydbusername"; //ENTER YOUR DATABASE USERNAME
$password = "mydbpassword"; //ENTER YOUR DATABASE PASSWORD
$dbname = "mydbname"; //ENTER YOUR DATABASE NAME
$conn = mysqli_connect($servername, $username, $password, $dbname);
if (!$conn) {
die("Connection failed: " . mysqli_connect_error());
} else {
$query = "SHOW TABLES;";
$mytables = mysqli_query($conn, $query);
while ($table = mysqli_fetch_assoc($mytables)){
foreach ($table as $k => $v){
$sql = "OPTIMIZE TABLE '".$v.";";
mysqli_query($conn, $sql);
sleep(5);
echo "$v Optimized<br />";
mysqli_close($conn);
