Recently I am seeing the following errors when processing bounces. Does anyone know how to fix this?
Processed messages will be deleted from mailbox
Database error 1406 while doing query Data too long for column ‘data’ at row 1
Database error 1366 while doing query Incorrect string value: ‘\xE9 ause…’ for column ‘header’ at row 1
I fixed the first error:
To do this I use PHPMyAdmin and opened the table phplist_bounce. I clicked the “Structure” tab, and then on the “data” row I clicked the “Change” link. I used the drop down box under “Type” and changed it from “BLOB” to “MEDIUMBLOB”.
Be sure to back up your database before doing this.
I still have this error when processing bounces, any help is appreciated:
Database error 1366 while doing query Incorrect string value: ‘\xEAtre l…’ for column ‘header’ at row 1
