Dashboard info icon tooltip translation?
Hi, can’t find ā€œHELPā€ translation in English phplist.po file
Related to
admin/ui/phplist-ui-bootlist/header_minified.inc
<button class="btn btn-xs btn-danger pull-right glyphicon glyphicon-info-sign" type="button" data-toggle="collapse" data-target="#helptarget" aria-expanded="false" aria-controls="collapseExample" title="<?php echo s('HELP') ?>"></button>
Is it missing or… may be :wink: elsewhere?
@Jessie Translations are taken from the phplist_i18n table. Search on the original column.
Thank you @duncanc but in this phplist_i18n database’ table (3.6.3), I can’t find this ā€œHELPā€ text (uppercase), only seen the following (about Community)
('en', 'pagetitle:community', 'Help'),
('en', 'pagetitlehover:community', 'How to get help and how to help out with phpList'),
@Jessie Possibly your translations are not up to date. Check the system > update translations page.
