I try to integrate in my own webpage a “simplified” form with some fields of the custom subscription page I made, using reCaptcha plugin of PHPList. I can’t manage to make it work : the form is never submitted. And I think it’s because I don’t know how to check the reCaptcha using the PRIVATE key… How can I do that ?
- in my_webpage.php :
<div class="newsletter">
<form method="post" action="http://www.mywebsite.be/newsletter/?p=asubscribe&id=1" name="form" id="subscribe">
<label class="mail">E-mail</label> Inscrivez ici votre adresse email :<br>
<input class="subscriberequiredField subscribeemail" id="subscribeemail" name="email" type="text" placeholder="adresse@mail.com">
<input type="hidden" name="htmlemail" value="1" />
<div style="display:none">
<input type=text name="emailconfirm" value="" />
<input type="text" name="attribute2" class="attributeinput" size="40" value="nom inconnu" />
<input type="text" name="attribute6" class="attributeinput" size="40" value="prénom inconnu" />
<input type=hidden name="subscribe" value="Subscribe">
<input type="checkbox" name="list[16]" value="signup" checked />
<input type="checkbox" name="list[17]" value="signup" checked />
<input type="text" name="VerificationCodeX" value="" size="20">
</div>
<div class="g-recaptcha" data-sitekey="MyPublicreCaptchaKey" data-size="normal" data-theme="light"></div>
<script type="text/javascript" src="https://www.google.com/recaptcha/api.js?hl=fr"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function() {
$("form[name=form]").submit(function(ev) {
if (grecaptcha.getResponse() != "") {
return true;
alert("Please complete the reCAPTCHA");
return false;
</script>
<input id="submit" type="submit" name="subscribe" value="s'inscrire !" onClick="return fillConfirmationField(form);">
</form>
</div>
- I have the following script :
$("form#subscribe").submit(function(evt) {
evt.preventDefault();
$("form#subscribe .subscribeerror").remove();
var s = !1;
if ($(".subscriberequiredField").each(function() {
if ("" == jQuery.trim($(this).val())) {
var r = $(this).prev("label").text();
$(this).parent().append('<span class="subscribeerror">Merci d\'introduire votre' + r + " ci-dessus...</span>"),
$(this).addClass("inputError"),
s = !0,
$("form#subscribe input.subscribeemail").attr('placeholder', 'tapez ICI votre adresse email svp'),
$("form#subscribe input.subscribeemail").focus()
} else if ($(this).hasClass("subscribeemail")) {
var e = /^([\w-\.]+@([\w-]+\.)+[\w-]{2,4})?$/;
if (!e.test(jQuery.trim($(this).val()))) {
$(this).parent().append('<span class="subscribeerror">Votre ' + r + " paraît incorrect...</span>"), $(this).addClass("inputError"), s = !0
}), !s) {
$("form#subscribe input.submit").fadeOut("normal", function() {
$(this).parent().append("")
var r = $(this).serialize();
$.ajax({
type: 'POST',
url: $(this).attr("action"),
crossDomain: true,
contentType: "application/x-www-form-urlencoded; charset=UTF-8",
async: false,
data: r,
success: function(data) {
//alert("OK : "+data);
$("form#subscribe").slideUp("fast", function() {
$(this).before('<div class="subscribesuccess">Merci !<br><span>Un email vous a été envoyé</span> pour confirmer votre inscription (vérifiez votre dossier "spam")</div>')
error: function(jqXHR, exception) {
if (jqXHR.status === 0) {
tech = " (connexion)"; //alert('Not connect.\n Verify Network.');
} else if (jqXHR.status == 404) {
tech = " (err404)"; //alert('Requested page not found. [404]');
} else if (jqXHR.status == 500) {
tech = " (err500)"; //alert('Internal Server Error [500].');
} else if (exception === 'parsererror') {
tech = " (parseerror)"; //alert('Requested JSON parse failed.');
} else if (exception === 'timeout') {
tech = " (timeout)"; //alert('Time out error.');
} else if (exception === 'abort') {
tech = " (aborted)"; //alert('Ajax request aborted.');
} else {
tech = " (jqXHR.responseText)"; //alert('Uncaught Error.\n' + jqXHR.responseText);
$(this).before('<div class="subscribeerror">Un problème est survenu' + tech + '. Envoyez nous un petit email à <a href="mailto:contact@mywebsite.com?subject=inscription à la newsletter ilia&body=Bonjour, voici mon adresse email pour recevoir les newsletters d\'ilia : [votre email ici]. Merci !">contact@mywebsite.com</a> svp. Nous prendrons note de votre adresse.</div>')
//alert("submit END");
return !1
Thank you very much for your help !
T.
