Longtime user of phpList - i was running 2.10.15 until last week when my server melted - it worked, didn’t need to upgrade.
New temporary server (CentOS 6, PHP 5.4) - I imported my DB backup, copied over my 2.10.15 directory from a backup, and was able to log back in. Thought while I was on a new server, I’d upgrade and try the new version(s).
Manually installed my way through 3.0.0, 3.0.12, 3.2.7, 3.3.9, 3.4.9, 3.5.9 & 3.6.2 - all successful upgrades, according to the process results and the DB verification mechanism inside phpList. each time a new /lists folder was created from the TGZ download, and the config.php file from the previous version was copied over.
FYI, i tried manually and via the updater to install 3.6.3 and 3.6.4, and both fail - the updater yields “can’t write” errors on every file under /lists, and manually, the login page won’t load. I’m assuming these are failing due to some PHP 7 specific call, but no error messages in the website error.log file, so no idea.
Under 3.6.2, I started a new campaign, and sent a test message to a couple of my emails - they worked, no problem.
However, i tried to import some emails from another source (I do this a couple times a month, have for years, no issues), and the import from CSV (email, fname, lname only, comma separated - verified via notepad, all emails valid) produces a white page, with nothing on it - no error message in the website error.log. I’ve tried test mode, i’ve made sure the comma is in the delimiter box, no combination works.
I repeated the upgrade process a 3rd time, stopping at 3.5.9 in hopes that any PHP 7 issues might not crop up, but again, the import process does the same thing.
Anyone have any insights? I’d appreciate the help.
Thanks.
