I need a cronjob to “Process the Queue” while my computer is not logged into phpList. I have it set to send 300 emails per hour (reduced to to my hosting providers restrictions) but I cannot afford to leave my computer running for days when I need to send a campaign to a large list. I have tried using the following commands:
lynx -dump http://www.mydomain.com/lists/admin/index.php?page=processqueue&login=admin&password=phplist
and
/usr/bin/php -c /usr/www/httpd/php5-ini/ftp username/php.ini /usr/www/users/ftp username/lists/admin/index.php –pprocessqueue
and
/usr/bin/php -c /usr/www/httpd/php5-ini/ftp username/php.ini /usr/www/users/ftp username/lists/admin/index.php –pprocessqueue -c/usr/www/users/ftp username/lists/config/config.php
Hi, check out this https://phplist.org/manual/ch035_methods-of-sending-browser-cron-command-line.xhtml
And this one, too…
https://phplist.org/manual/ch036_setting-up-your-cron.xhtml
your task is to figure out what the command is EXACTLY for your particular server.
Try this one:
php /home/YOURDOMAIN/public_html/lists/admin/index.php page=processqueue login=admin password=YOURPASSWORD >/dev/null 2>&1
I set it to run every 5 minutes…still will stop on occasion, not sure why.
