@dreamcreator Thanks.
I don’t really understand the problem that you are trying to describe. It appears that the cron job is running successfully once an hour. Can you see in phplist that the campaign is being sent?
What is the email that has the URL with the extra apostrophe? It does not look to be to do with phplist, so you should raise that with your hosting company.
Cronejob is set to send email to me in case there are some falures.
I have 3 testusers and thay get messages so I hope all other too.
On some point by plesk or phplist this apostrophe will be added to clean URL and I get hourly message about 400 failure
I guess it is some plesk bug and maybe you have noticed similar…Provider wanted money from me to investigate this allthou plesk is a part of their service.
