What is the difference between UUID and Unique ID?
In the phplist manual it states:
In the mysql reference manual for guidance on using regular expressions in mysql.
As an example, to match email addresses on the gmail.com or yahoo.co.uk domains the target value should be (yahoo.co.uk|gmail.com)$.
Or to select an arbitrary 20% of subscribers using the subscriber id field the target value could be [01]$. This selects subscribers whose id ends in 0 or 1, which will select approximately 20% of subscribers.
Are they referring to UUID or “Unique ID” as each subsribers record has both.
Thank you.
@pancakehollow You seem to be looking at the documentation for the Segment plugin but your question isn’t directly to do with the plugin.
It is referring to the id column of the user table, which is separate to both the UUID and Unique ID fields.
Hello and thanks for that. I’m looking at the paragraph titled “Evaluating Conditions” in the Segment Plugin because I couldn’t find any examples of how to use Regex in the Segment Tab availalbe to me when choosing subscribers to send a campaign to.
Indeed it works properly it would seem when I use the users Unique ID following the regex example for the segment. But it also works for the UUID which I always thought was Unique User ID. Thus it’s easy to confuse the two when the instrucitons for using regex state:
Are you suggesting I look up the users via regex in mysql against the id column in that table? That seems like a difficult maneuver given that the plugin is designed to do exactly that - albeit without the confusion resultling from the use of “User ID”.
@pancakehollow I don’t understand what you are asking. The documentation refers to the id column of the user table. What is unclear about that?
When composing a campaign, the drop-down list on the Segment tab has “Subscriber unique id”. That is referring to the uniqid column. The plugin doesn’t support the uuid column.
Take a look at the images.
One is lifted from plugin:segment [phpList Resources] and it states, when trying to drill down into a specific user or users, the admin can use regex. That’s a great feature!
In the “Evaluating Conditions” paragraph it states. "Or to select an arbitrary 20% of subscribers using the subscriber id field the target value could be [01]$. This selects subscribers whose id ends in 0 or 1, which will select approximately 20% of subscribers.
Great! When using the drop-down selection there are two choices about ID’s: “Subscriber ID” and “Subscriber Unique ID” both of which presumably use regex. And yet if an admin actually opens the phplist record for an email user (see image id.png4 ) and since the documentation only states “Subscriber ID” we are left scratching our heads wondering which field represents the “Subscriber ID”: is it the field called “Unique ID”, or “UUID” or “ID” (at the top of the record) all of which are different animals from each other.
There is nothing called “Subcriber ID” in a user’s record.
You say:
But how would anyone know that unless they opened the mysql database which is not suggested in the “Evaluating Conditions” with regex, tutorial. In fact it’s pretty clear that the documentation suggests users to view the phplist email accounts record.
You don’t see how that can sow confusion?
In terms of the identifiers used by the plugin documentation or code and the phplist subscriber details page
Subscriber ID => ID
Subscriber unique id => Unique ID
Just checked the plugin documentation and the Purpose section does clarify what these mean
- subscriber id (the incrementing number assigned to each subscriber)
- subscriber unique id (the 32 character value assigned to each subscriber)
Thank you! I never would have found that. Always good to have another set of eyes.
