I have been using the following for years…
$commandline_users = array(“jose”, “jondi”, “ctab”);
as of three days ago the system quit sending and it boiled down to the array. I changed it to the basic array below and the emails are now going out again.
$commandline_users = array();
@johntrot Not sure; did you upgrade phpList or your server system packages over the last few days? Any updates or changes to the shell that you’re using could have caused it, or perhaps change to the unix users on your server. Was your version of PHP upgraded?
phpList’s commandline system for user management hasn’t changed in years as far as I can recall.
Interesting that the problem coincided with the PHP upgrade; were other packages upgraded at the same time which relate to your shell or PHP extensions?
