Hello
I would like to include phone links in my campaigns, eg. 000-111-2345
However, as expected tracking code is added to phone links like any other link and you end up with something like this:
000-111-2345
The converted link above doesn’t work on my phone – is it possible to prevent tracking for special links you want skipped?
Thanks and keep up the great work!
@andredt1980 Please use the code button </> when entering html so that we can see the actual html.
phplist considers only http and ftp protocols for link tracking, so other protocols such as mailto: or tel: should be unchanged.
Ok, muchas gracias duncanc por responder.
Que debería poner para que funcione bien?
Ok, thank you very much for answering duncanc.
I should put it to work well?
