Problem Statement
Click-links in subscriber emails result in 404 errors when attempting to use them.
Current Configuration
`$pageroot = ‘/list’; (Note the /link (no “s”) from install. This is different than the default “/links”. All site and messaging acticity works as planned except for the incorrect email links causing the error.’
Diagnosis
- An extra config.php $pageroot value is being added to the URL after the message is created. The same extra $pageroot value is being added to text-only messages.
- Email links to subscribers gets changed to = ‘http://domainname.com/list/list/…’; (extra directory added into link resutls in 404 Error).
- The [WEBSITE] variable looks related to the issue. The url/link text in the emails is correct when we save the message. Then the extra %pageroot appears to be added somewhere after that.
Configuration Change Test 1
$pageroot = ''; (After reading DO NOT DO THIS - we did it anyway). Others indicated that this solved the issue - though it seems to be a workaround and not a fix.
Configuration Change Test 1 Result
- Links worked correctly in the test emails because the extra %Pageroot was removed the link.
- The URL for both HTML and text messages was correctly formed.
- Persistent warnings screen and at login about %pageroot being changed.
Reset Configuration to Install
- After testing, we reset $pageroot = ‘/list’;
- The extra %pageroot reappeared in the email links. The site works as planned except for this issue.
Questions
- Where else can these extra email %pageroot variables being added?
- Is there another easy way to solve this problem?
