I upgraded my old server from 2.10.10 to the great 3.6.1, it works very well and I love the new layout, functions and especially the tracking function.
But I have a small “problem”, when I create a message with the new editor (CKEditor) there is some space between the images. With the old editor (I also tested disabling CKEditor and enabling the old one), it doesn’t happen.
I try to remove the space in the html code, but it doesn’t work. Any solution? I need to use split images because I need to create hyperlinks for each product.
I also try your sugestion (remove cells, only use images) but the gap still appers on gmail.
In fact on PhpList preview message where is no gaps, so the issue maybe is on the gmail viewer
@duncanc WOW you are my savior!!! Works perfect, thank you so much! You are a HTML God!!
Now I’m explore all new phplist features, and I found the Template option. With this I can make my header and bottom common to all campaign one time only and works very well.
With your new code to remove the gaps on GMail viewer I do the same on template and fantastic. But I have one line with 3 images, sellers contacts, if I use “display: block” is one image for line, I try “display: inline” and “display: inline-block” with no success to remove the gap to the next image.
